Page 5 of 14 1 2 3 4 5 6 7 13 14
Re: Subframe connectors, which way should we [Re: Fasbird] #981
01/19/04 04:47 PM
01/19/04 04:47 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Tim Moffet, could you repost the pics on the bottom of your car with your design of 2 pc welded frame connectors? When this original thread was going around I missed it and the pics dont show up now that I located the thread. Thanks.
Re: Subframe connectors, which way should we [Re: BADBEE] #982
01/19/04 04:53 PM
01/19/04 04:53 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
wow talk about back from the dead...
Since this post, I welded mine in 90° to Zippy, no floor pan welds, and boy what a difference it makes!! I'll post some pics because of they are similar to Tims:
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: Subframe connectors, which way should we [Re: whiplash] #983
01/19/04 04:54 PM
01/19/04 04:54 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
two..
Re: Subframe connectors, which way should we [Re: whiplash] #984
01/19/04 04:56 PM
01/19/04 04:56 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
three..
Re: Subframe connectors, which way should we [Re: whiplash] #985
01/19/04 04:57 PM
01/19/04 04:57 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
four...
Re: Subframe connectors, which way should we [Re: whiplash] #986
01/19/04 04:58 PM
01/19/04 04:58 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
five... check the emergecy brake cable...
Re: Subframe connectors, which way should we [Re: whiplash] #987
01/19/04 05:00 PM
01/19/04 05:00 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
six...
Re: Subframe connectors, which way should we [Re: whiplash] #988
01/19/04 05:21 PM
01/19/04 05:21 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
I thought that would freak some people out when I posted to this old thread. Thanks for the pics whiplash. So you didnt weld yours to the floor pan? Is your a one or two piece steel tubing?
Re: Subframe connectors, which way should we [Re: BADBEE] #989
01/19/04 05:29 PM
01/19/04 05:29 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
Single piece. Straight, no bends. I think Tims is ine piece, but he just cut a triangle out and bent it closed/welded shut the hole so the back of the bar angled up.
Re: Subframe connectors, which way should we [Re: whiplash] #990
01/19/04 05:42 PM
01/19/04 05:42 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Thats why I was hoping I could get Tim to post his pics since our cars bottoms are very similar.
Re: Subframe connectors, which way should we [Re: BADBEE] #991
01/19/04 06:09 PM
01/19/04 06:09 PM
Thanks to Ma Mopar the floor pan on '65's B Bodies is nice and flat. No reason to cut the floor pan(s) to recess the subframes when the rear subframe is on the same plane as the floor pans.
Re: Subframe connectors, which way should we #992
01/19/04 06:12 PM
01/19/04 06:12 PM
Floor pan at rear sub-frame, with connector welded in place
Max
Re: Subframe connectors, which way should we #993
01/19/04 07:00 PM
01/19/04 07:00 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Good evening ladies and gentlemen, and welcome to the post that wouldn't die!
Glad to see it's still worth discussing, and good to see more jumping on the bandwagon and getting it done.
Rich H.
Esse Quam Videri
Re: Subframe connectors, which way should we [Re: ZIPPY] #994
01/19/04 07:36 PM
01/19/04 07:36 PM
here's some old pics of mine...
Re: Subframe connectors, which way should we #995
01/19/04 07:37 PM
01/19/04 07:37 PM
Re: Subframe connectors, which way should we #996
01/19/04 07:37 PM
01/19/04 07:37 PM
Re: Subframe connectors, which way should we #997
01/19/04 07:38 PM
01/19/04 07:38 PM
Re: Subframe connectors, which way should we #998
01/19/04 07:39 PM
01/19/04 07:39 PM
Re: Subframe connectors, which way should we #999
01/19/04 09:12 PM
01/19/04 09:12 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Max....do you have any more pics of the installed sub connectors? Maybe one from the side showing the whole length? I plan on putting subs on mine this winter/spring....I'm glad I wont have to cut my new rear pans to install....gotta love the early B's!!!!
Excellent thread btw....
Re: Subframe connectors, which way should we [Re: nomore65BelvJim] #1000
01/19/04 09:56 PM
01/19/04 09:56 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Great timing! I am starting to do this to my Dart as well
Todd/Zippy/Clonestocker
The idea of putting connectors into the rear frames has been something I'll do too, but since I am relocating the springs into the frame rails, would butt welding the 2x3 to the new spring boxes add any strength?
Wize
Your thoughts on biasing the chassis are interesting. The circle track guys have a system for that, and I suspect Pro Stock etc have their chassis' assembled with some sort of preload.
It would be interesting to see if putting a twist into the car to counteract torque would do. But can that be done simply?? And done with a turnbuckle type system for adjustability??
One last thing-
My Dart is on stands for leveling fore and aft. However, the left front will not sit on the jack. Will I need to weight the car to get it to flatten out? Or is that normal. The engines & trans are out of the car
-Ken
