I tested a 750 Mighty Demon on my 340 in place of the 650 speed demon it currently runs. The mid range and top end where awesome and the idle quality was atually much better.
The engine shop can get me a 650 Mighty Demon -all he says I need- or they also deal with Quick Fuel but he wont recomend the Quick Fuel because I haven't tested it. I like the idea of a choke but its not a deal breaker.
Which way would you go?
Car specs below.
Stock J Heads 2.02 intake 1.60 exhaust and Crane Gold 1.5 ratio rocker arms.
3.55 gears and a 727 with 3000 stall from SMR, stage 2 shift kit from transgo.
It runs a Hughes cam #heh2328al
111deg lobe seperation/installed centerline 108deg
intake lift .506/ exhaust .524
Duration@.050 Intake223deg/ Exhaust 228deg
Cam timing @ .050” Tappet Lift
Intake Opens: 3.5 Deg BTC
Exhaust Opens: 48 Deg BBC
Intake Closes: 39.5 Deg ABC
Exhaust Closes: 0 Deg ATC
Engine is .060 over with Keith Black Hypereutectic pistons on stock rods and a stock forged crank.
Ignition is an FBO box
