You got a budget in mind? That would really impact the direction you go but I prefer Firm Feels stuff
Honestly, I don't have a total budget in mind, but I'd probably like to work in about $500 increments. Forgot to mention I also already have a Firm Feel stage II steering box in the car. The car needs an alignment, so I should perhaps base my first changes around the things that will most effect the alignment. I guess that would be offset bushings or tubular UCA's, and any polyurethane bushings I'm going to use. I can do the T-bars later and set the same ride height.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
