Re: Driveline vibe, pinion angle
[Re: desomod]
#993946
05/17/11 02:14 AM
05/17/11 02:14 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
...Also in checking driveline angles, the pinion is 3* up, the trans tailshaft is down 3*, the driveshaft was nearly in line with the pinion. I know there needs to be a few degrees of driveshaft angle to lube the u-joints but do you think the way this sits it would cause vibration?
Yes, I've heard it will cause a vibration and excessive wear, but it may not be the sole source of your vibration. The u-joints need to have some movement as the driveline rotates. You can use shims to nose down the rear 3 or 4 degrees.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
