Driveline vibe, pinion angle #993944
05/16/11 10:11 PM
05/16/11 10:11 PM
desomod Offline OP
desomod  Offline OP
Cuda, 528 Hemi,727,8 3/4. While on the dyno last week noticed a pretty significant vibration as RPM increased. I have pulled the driveshaft and will have it checked for balance and runout. Also in checking driveline angles, the pinion is 3* up, the trans tailshaft is down 3*, the driveshaft was nearly in line with the pinion.
I know there needs to be a few degrees of driveshaft angle to lube the u-joints but do you think the way this sits it would cause vibration? It has a SFI flex plate and the converter is a unknown.
Re: Driveline vibe, pinion angle [Re: desomod] #993945
05/16/11 10:37 PM
05/16/11 10:37 PM
I will defer to Doctor Diff (& others) for the final word on this but I think you want the pinion down (neg?) several deg as it will rise on accel
Re: Driveline vibe, pinion angle [Re: desomod] #993946
05/17/11 02:14 AM
05/17/11 02:14 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
...Also in checking driveline angles, the pinion is 3* up, the trans tailshaft is down 3*, the driveshaft was nearly in line with the pinion.
Yes, I've heard it will cause a vibration and excessive wear, but it may not be the sole source of your vibration. The u-joints need to have some movement as the driveline rotates. You can use shims to nose down the rear 3 or 4 degrees.
Re: Driveline vibe, pinion angle [Re: jbc426] #993947
05/18/11 11:01 AM
05/18/11 11:01 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Pinion should be nose down relative to the driveshaft.
Are you saying your tailshaft is down relative to the driveshaft? Is this from a lowered car? Usually a driveshaft is down from the transmission.
You said the pinion is almost straight to the driveshaft. 3 degress is not much at the other end but if your goal is no vibration. The answer is matching angles. The less the better. Since I agree zero is not good for universal joint bearings. 1 to 2 degrees max.
