If you are willing to delete the mechanical fuel pump, you can mount the A/C pump below the alternator as you have seen on Big Blocks. The brackets could certainly be fabbed easily by anyone with some imagination using a sawzall and a drill.
I agree that A/C is nice to have and that a concealed unit helps maintain a cleaner looking engine bay. Good luck.
