03= gate
149 = base number
262919 = sequence number or basically the way John described it.
69 LR coded C16 for both the console and the buddy seat so just seeing this code on the tag really doen't tell you which it recieved.
paint code 97 GTX= VERY uncommon.
97 and 97 paint code = roof and body were Rallye Green
P6C = blue and white interior. The code is actually P6G for green interior to go with the exterior. (The tail is missing from the G. Compare the G to the C in C16) F8 = UDF color
Yes. nice car
So the roof was painted 97 but a black vinyl top put over it? Also, the V68 longintudinal stripe delete would be the stripe following the missing rocker trim? Is there anyway to tell if the car had the trim deleted without attacking the paint? Anyone ever see a 69 GTX without the trim from the factory? I am not up on these cars, I only know Darts, so any info would be appreciated!
I should have known the 68 was V68!! seems I could remember that 1X was V1X but not that 68 was V68........I have no excuse! Oh well, I am getting better!
I would imagine that the 97 code paint is VERY rare.....I wonder if anyone has the '69 paint percentages for GTX's.
You can argue with me if you like ... ..
Upper door color is F8 , it's the code after the P6G
