Getting into the assembly phase of my small block stroker. There is some light rust in the lifter bores that I need to remove. What's the best method to clean these out? Can't seem to find a wire brush that will fit the bore. Maybe a scouring attachment for my dremel?
Yes, I'll definitely make sure the lifters spin freely before I assemble.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
