Re: Motorhome 440,,carb@intake,,what choice's
[Re: Twostick]
#967962
04/07/11 01:03 PM
04/07/11 01:03 PM
Posts: 13,247 Mt. Vernon, Ohio
dartman366
Mt. Vernon, Ohio
I'd eliminate the obvious like fuel delivery and vacuum leaks. Assume nothing. New fuel pumps can under-perform and that thick base gasket for the TQ will leak if it's re-used too often. What is the timing at? Vacuum advance? The stock intake is WAY better than most will give credit for so it would be the last thing I would change. Can you borrow a TQ that is known good?
Kevin
new base gasket when the carb was put back on, I am not sure of the timing, I will have to investigate as to how difficult it will be to find the timing marks, then figure out where it should be set at, I would even concider a non smogger stock intake, as far as a different carb I will need to talk to a few friend's and see if they have somthing.
As far as YOU Ted, I have a spare Dommy for the car and I have seen M1's at swap meets so don't get me thinkin'........how about a tunnel ram and twin 750's.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
Entire Thread
dartman366
04/06/11 10:49 PM
dOoC
04/06/11 10:59 PM
scratchnfotraction
04/07/11 12:20 AM
dOoC
04/07/11 12:29 AM
feets
04/07/11 12:29 AM
dartman366
04/07/11 01:26 AM
dartman366
04/07/11 01:30 AM
Phil Saran
04/07/11 02:02 AM
dartman366
04/07/11 02:23 AM
dOoC
04/07/11 02:36 AM
dartman366
04/07/11 02:41 AM
dOoC
04/07/11 03:15 AM
U code RR
04/07/11 03:24 AM
dOoC
04/07/11 03:33 AM
dartman366
04/07/11 03:42 AM
dOoC
04/07/11 03:45 AM
dartman366
04/07/11 03:59 AM
dOoC
04/07/11 04:12 AM
dartman366
04/07/11 04:26 AM
dOoC
04/07/11 04:34 AM
dartman366
04/07/11 03:29 PM
tboomer
04/07/11 03:34 PM
Twostick
04/07/11 04:52 PM
dartman366
04/07/11 05:03 PM
Twostick
04/07/11 06:00 PM
dartman366
04/10/11 12:56 AM
dOoC
04/10/11 01:52 AM
dartman366
04/10/11 02:35 AM
dOoC
04/10/11 04:08 AM
dartman366
04/10/11 05:07 AM
dOoC
04/10/11 06:46 AM
MowP4rsn
04/10/11 06:52 AM
dOoC
04/10/11 07:00 AM
MowP4rsn
04/10/11 07:24 AM
dartman366
04/10/11 11:11 PM
Twostick
04/10/11 03:32 AM
RapidRobert
04/07/11 01:21 AM
