You RTV-only guyz think about this. You pop the pig out and you scrape and scape THEN you put a bead on and spread it out carefully .....
What-the-fugg ....
... by the time you do JUST THAT ... I could do the whole pig-change
Whatcha' do is GLUE the gasket onto the housing and make sure that the case-face of the pig is super-clean and lightly oiled and the pig-swap is a pieceOcake !
It has been awhile since I have swapped one out .... but my wife timed me once ....on the ground, floor jack, jack-stands and an electric impact gun ......
.... 21 minutes !
