actually with a good power coming from alt and healthy wiring, the B+ source it can be wired from alt post too
the KEY source it can be the blue wire ( brown in 70 and lates ) going from ballast to coil.
Or if thinking on remove ballast resistor, then use the blue wire ( all years ) originally feeding ballast and regulator
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
