Quote: I have done MANY 727 and 904 transmissions ...and I don't think that I have seen more than TWO trans with a spun cam.
AGAIN ...spend you $$$ as you see fit.
I had a bolt in c6 sprag in my 727 and it only lasted about 8 passes and it rolled the rollers and busted the case. Not sure why. Always did secound gear burnouts and car seemed to hook up pretty dang good.Now I have about 25 passes on the new trans and seems to be working ok.
