Quote: John, Does the A&A Ultimate Sprag use 1/4 bolts with compression ferrels?
The Coan says it uses 8mm shoulder bolts, and the case bolt holes need to be enlarge since that is slightly larger than the stock 727 5/16 bolts that thread into the case (not the sprag).
