I run a constant voltage soleniod on my car. There is no need for a relay then. The constant voltage soleniod will only need 9v to activate it. Yhe pump will get full power then. Just a thought..
I run both of my pumps off the constant voltage soleniod.
And no it is not a ford soleniod.. They are not intended for constant power.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
