This might help.
http://www.pacificp.com/pdf/Fuel%20Pump%20Relay%20Unit%20%28Online%29%20Diagram.pdf
thanks, that's it. I could remember. last I did one the battery was in the trunk. I'll switch it up. Hope to get it fired up today.
the 85 post can that go to the switch or should it run to the key on then the switch?
Do you want to run the pump with the engine off? You can wire it either way but since the only reason to run it is when the engine is running it makes sense to feed it from a key on power source..
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
