Quote: man what ever happened to people actually having to work to get things to fit? Everyone thinks that you buy aftermarket parts and they just bolt on, YOUR WRONG. However the pump does work with stock hemi mounts. just get a little creative
I understand what you are saying, that non-stock doesn't always fit. However, when designing an aftermarket part, it should take stock tolerances into account. They should have a stock block with stock parts bolted to it for fitting. They should also have at least their own aftermarket parts handy for fitting. They might as well sell you a chunk of billet if you gotta machine it to work, especially if they will not warranty the part if any mods are made to it. Would you consider purchasing it if the pump extended into the block area or tilted the filter up where headers normally reside? It's just poor planning on the company's part that it modified the part to extend from stock space into a known tight area.
