Does anyone know if a grille surround bolt/nut kit is available? I'm looking for the self tappers that attach the Upper (4), Sides (8) and Center Support (2), plus the 4 nuts (presumably with captive washers) that attach the rear of the frame surround to the fenders.
In case anyone is interested, the bolts/nuts just referenced are all those that are needed to be removed (with bumper removed) in order for the grille assembly to be separated from a 68/69 Charger.
