Typically shops have a minimum of 250-300 hrs just for prep and paint on the exterior body, you're talking about doing the complete underside as well. You've done restoration work in the past so you should have an idea of how much time it will take to dismantle and strip the shell...
I personally think you're robbing yourself if you quote anything less then 500 hrs...
....and if Alan says 500, you should probably plan on 600! mine took 600 and I had taken the car apart and got it back as a rolling shell.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
