TRUE Mopar powered meaning Indy, B1, and Hemis are allowed, and others....not Predetors and parts that are not truely Mopar factory based stuff
You consider B1's and some of the Indy's with relocated valvetrain's factory based ???
I SURE do....they do have relocated parts but all of these began with the Chrysler Wedge head in mind only modified AND they will bolt to a Mopar block other than the higher-end stuff. Predator heads and HEMI 99 stuff is awesome but the only thing Mopar about it is the name on the valvecovers. I dont think a set of 440-1 headers will bolt up to a Predator head??? They can be used on stock type heads....we have done it....so again to answer your "comment" YES.
