Ari/Josh
Are you guys mini-tubbed? I was curious also if the 295 would look shorter than the 28". I like the way the 29.5 looks under a Duster. My spring offset kit is also set up to move the rear end back 1". I am hoping that will at least give me the option for a 29.5.
My main question is can I get a 295/55 under the car with just a spring offset kit and a stock fenderwell.
A 295 drag radial is taller than a 28" slick....
