Re: Iron Head Compression Limit
[Re: R/T1968R/T]
#914306
01/27/11 04:26 PM
01/27/11 04:26 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
Im using SRP flat top pistons, they are .022 below deck. steel shim head gasket, .019-.020. Quench appears to be near perfect. The car is a 68 Charger, 4 speed , dana. I have a choice of many gears from 3.55s all the way to 4:88s. Im in a catch 22 position, I want to run HP exhaust manifolds and I think about 242 duration @.50 would be pushing it with the manifolds (According to AndyF and his tests).More cam might kill the bottom end!
dont believe everything you read,those tests were with 1973 400 manifolds,and unported also. i have custom ground solid cam for fast class type car hp manifolds/powerbrakes 550/540 lift 112lsa that i dont need now. had close combo 440 like yours 40 over 440 ross flat tops/big valve 915s,all stock trim. now went of the deep end 500 inch 440 with roller cam 602/603 lift252/257 duration@50 114lsa still gunna run manifolds and power disc
MOPAR OR NO CAR
