if you really have .o42 quench i would say you will be OK at 34 deg total timing but i would definitely not try to lower it by shimming any thing .
because a 9.1 compression motor no quench will ping more than a 10.5 to one motor with tight quench this is a FACT .
quench is like octane the more you can get the better as long as the motor has clearance .
1969 Dodge Charger 1969 Dodge Superbee
