I cant make up my mind about the flex pipe. I have solid motor mounts and a 10/12pt cage will be going in. Will I be fine as is? Should I add one in the 3" section after the merge? Should I add one in the passenger side piping before the merge or should I do both?
2000 dakota 418 magnum paxton novi 2k T56
