Alright I guess I was just over analyzing things my bad. All I wanted to do was change the fluid now look what I got into .
The springs feel close in tension just one spring is made longer for tension and the other is thicker.
the shorter spring is a much higher rate, most likely.
for what is the good life if not doing things thoughtfully?
