I have tried acouple different hood scoops also..a hemi and six pack and they dont work either..I love the cowl..if I redo the hood it will be a 6 inch that goes to the windshield..I need to put a good aero scoop on it,but hate to deface the car with it..I run such a big cfm carb..it needs all the airflow it can get..
Been running the carb out the scoop hole and running a big aircleaner on it..just for testing mode purposes..
Ever try anything like the PS trucks had? Cowl hoods with a front facing airpan. Aerodynamic benefit of the cowl and just redirect air that would hit the front of vehicle anyway.
I like the looks of the cowl, however I'm just not subscribing to the "air off the windshield" lore.
My 6" cowl goes back to an inch or so of the windhield and has a 2pc forward facing pan setup. Still sorting out electrical issues and have not had it over 140 yet, which is where I expect it to start making a difference.
Good Luck
I've wanted to test my scoop VS a cowl in cars that
run the same speed... just putting a inches of water
gauge with a pick up tube in the cowl and scoop...
at least I know that if the front facing scoop is
high enough to be in the air flow it applies pressure
at speed where the six pack type arent high enough
and may actually hurt performance
