A bolt on hood for a Dart you can not have the end close to the window or it will not hinge up. The end of the cowl will hit the window. I've had both, 5" bolt on and a 6" lift off. I'll see if I can dig up pics of both.
Thanks Iam not going to use the hinges for a bolt on I was just thinking the bolt on is reinforced and would not buckle at the front of the hood only using two pins on the corner at the front of it.
