Hemi stroker (purchased the block ,heads and intake from you when you were at Westoaks) Mopar/Edelbrock heads mild port job,Vanke modified factory intake with 2 x 650AVS, comp custom high energy street roller. 244/255@.050 .575/.582 on 112 lsa. real soft springs #comp 953 are 150 on the seat and 425 open. 10.7 comp, factory exhaust manifolds. Engine pulled clean through to 6500rpm and made max HP of 632 @6100.
I look at it this way, you only have to wipe one flat tappet cam and its cost you more than putting in a roller the first time.
