Andy...Thanks for your input! I have thought about a 470 but naturally there is no substatution for cubic inches. Do you know the horse power and torq of the engine you built? Do you know what the gram weight of the rods and pistons? Did it rv up quick? One of the things I want the engine to do is rev up very quick and I will be using a 4-speed Hemi transmission so if I can get the engine to pull at 7000 RPM that would be great!
