I have looked at a few Mopar sites that have stroker kits to make a 500 cu. inch using a 400 block. It is my understanding that this combination using a 4.15 stroke crank the engine life is shortened because the piston is short. Can anyone give me more information on this or tell me who makes a very dependable 500 cu. inch stroker? The engine will be used a little on the street mut will be used at the track also. Thank you!
