Re: stock 440 pistons, how far down in the hole?
[Re: JohnRR]
#83458
07/04/08 01:58 PM
07/04/08 01:58 PM
Posts: 4,931 Tri-Cities, Washington
VITC_GTX
Trying to figure out the compression in my '70 GTX with original 440 (without tearing the motor apart). I'm getting tired of fighting pre-detonation and want to try and do something. First thing I want to do is figure out my CR.
I have ported 906's that are shaved .006" (assuming 78 cc's), .030" over bores, stock replacement forged pistons. If I can find what the average depth of the pistons are (and look at compression thickness of my head gaskets) I can closely estimate my CR.
What's the average depth in the hole for a '70 440?
Van lets try to actually ANSWER your question instead of GUESSING what you have .
heads shaved , by you ? if so what head gasket did you throw it back together with ?
I did not put the motor together. I have all receipts showing parts and head machine work. The receipts shows that the heads were shaved .006". I know I can't count on everything I read (or believe everything Ma Mopar said) but I was just trying to see if I have a compression problem, quench problem, or another problem.
Entire Thread
VITC_GTX
07/03/08 02:52 PM
DaytonaTurbo
07/03/08 03:46 PM
JohnRR
07/03/08 05:38 PM
VITC_GTX
07/03/08 06:23 PM
07/03/08 06:49 PM
JohnRR
07/03/08 07:01 PM
07/03/08 07:03 PM
JohnRR
07/03/08 07:09 PM
07/03/08 07:12 PM
JohnRR
07/03/08 09:26 PM
07/03/08 03:46 PM
Classof70Chally
07/03/08 04:53 PM
maximum entropy
07/03/08 09:35 PM
JohnRR
07/03/08 09:42 PM
John_Kunkel
07/03/08 07:59 PM
DaytonaTurbo
07/03/08 08:31 PM
JohnRR
07/03/08 09:30 PM
dave571
07/04/08 01:56 AM
DaytonaTurbo
07/04/08 04:19 AM
440beep
07/04/08 06:54 AM
JohnRR
07/04/08 02:21 PM
John_Kunkel
07/03/08 10:49 PM
07/04/08 04:33 AM
Mr.Yuck
07/04/08 01:35 PM
stumpy
07/04/08 02:15 PM
JohnRR
07/04/08 02:25 PM
stumpy
07/04/08 03:57 PM
VITC_GTX
07/04/08 05:58 PM
1_WILD_RT
07/04/08 07:11 PM
JohnRR
07/04/08 07:52 PM
GTX70sixpack
07/04/08 08:32 PM
VITC_GTX
07/04/08 10:04 PM
