Re: stock 440 pistons, how far down in the hole?
[Re: DaytonaTurbo]
#83435
07/03/08 01:38 PM
07/03/08 01:38 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
If it's a factory 1970 6 pack motor, your pistons should be about .02 in the hole. If it's not a factory 6 pack motor from 1970, then your pistons should be about .09 in the hole. That is assuming your block's deck, pistons, rods and crank are all exactly to blueprint spec.
.090 for a non 6pk ? whats the compression ratio that the factory stated in 1970 ? if its the same as 69 on the HP 440 it would be 10.0 , that piston will be .040 in the hole at blueprint .
oh , and yes a 906 is assumed at 86-88cc but its more like 90-92cc , general rule of thumb is you remove 1cc for every .005 you cut off a 906
Entire Thread
VITC_GTX
07/03/08 02:52 PM
DaytonaTurbo
07/03/08 03:46 PM
JohnRR
07/03/08 05:38 PM
VITC_GTX
07/03/08 06:23 PM
07/03/08 06:49 PM
JohnRR
07/03/08 07:01 PM
07/03/08 07:03 PM
JohnRR
07/03/08 07:09 PM
07/03/08 07:12 PM
JohnRR
07/03/08 09:26 PM
07/03/08 03:46 PM
Classof70Chally
07/03/08 04:53 PM
maximum entropy
07/03/08 09:35 PM
JohnRR
07/03/08 09:42 PM
John_Kunkel
07/03/08 07:59 PM
DaytonaTurbo
07/03/08 08:31 PM
JohnRR
07/03/08 09:30 PM
dave571
07/04/08 01:56 AM
DaytonaTurbo
07/04/08 04:19 AM
440beep
07/04/08 06:54 AM
JohnRR
07/04/08 02:21 PM
John_Kunkel
07/03/08 10:49 PM
07/04/08 04:33 AM
Mr.Yuck
07/04/08 01:35 PM
stumpy
07/04/08 02:15 PM
JohnRR
07/04/08 02:25 PM
stumpy
07/04/08 03:57 PM
VITC_GTX
07/04/08 05:58 PM
1_WILD_RT
07/04/08 07:11 PM
JohnRR
07/04/08 07:52 PM
GTX70sixpack
07/04/08 08:32 PM
VITC_GTX
07/04/08 10:04 PM
