You need this... http://cgi.ebay.com/ebaymotors/1970-74-C...sQ5fAccessories
It's the only piece that's different. Yes this fits an E Body
Nope, the driver side is different too. But not much. I think its about 1/2" narrower. The slots in the radiator often let you use the stock 22" side as there is enough play. I have pics somewhere.
I would use that conversion piece rather than changing the whole support; otherwise you lose your VIN.
He never said anything about ditching the original top crossbar , both sides are different, one would replace both sides if they wanted to do it right and reattach the original crossbar .
