I'm a dealer for PG stuff here in ontario, So call me biased but I look at it this way... If you can't find nice original stuff, then PG is a good option... some of their items are excellent some are garbage, but all can be made to work if you have no other option...
we're having an issue with the charger side marker where the bulb doesn't fit or turn into the socket, and one of ours fell apart on install also, but we're making it work, the bezel is nice and thats the important part! The charger taillights they sent are pretty nice...
It's hit and miss for every supplier out there for aftermarket stuff. They all have items that are good and bad...
As for china and u.s. made... look at the bare steel patch panels from cross canada or sherman auto parts....They are u.s made and are about the crappiest thing I've ever seen offered, my 10 year old daughter could form them better! Don't put your faith in what part of the world it comes from!
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
