Just got the car back from a professional chassis shop. They put new rear coil overs on as requested, scaled the car, and adjusted the pinion angle. I'm sure the 4 link is close and the shocks/tire pressure is more of the issue. I'll jack it up and find the C of G and then measure from the rear tires to get my numbers and double check the 4 link settings.
