Take the relucter out of the dist,pull the advance weights and look for the advance # on the part that holds the weights. whatever the number is you double it.(if it is 11.5degrees x 2 is 23 degrees) Subtract that from 35 degrees and you will have your initial timeing.
With the x-heads I would shoot for 35 degrees total.
Dennis Jokela
I started out with nothing,and I still have most of it.
