If you want to take Pacnorthcuda's advice a step further. Set the toe yourself and make sure the tie rod assemblies are equal length. This will center the centerlink, few technicians will take the time to do or check that. Understandable since few cars need that.
Won't the link be centerd if the steering wheel is straight?
09 Challenger B5 Classic 78 Magnum GT Check out my Website http://home.comcast.net/~tlyerk/troy1.html
