hi
rotateing the plug wires 1 space counter clockwise then reset timing by rotateing dist counter clockwise same ammount .
or if this is wrong direction go clockwise !
not sure where you are tight ?
I am tight on the retarded CCW direction. So its as simple as moving all the wires CW a few spaces and then reset timing? I do not have to do anything with the distributor gear?
