w the cap off, hand turn the crank w a 1&1/4" socket/breaker bar until a reluctor blade is lined up w the magnet. Then turn the housing (in the direction you need to) until the magnet is lined up w the next reluctor blade then shift the wires 1 position and fire it up & time it.
