Re: distributor position?
[Re: Viol8r]
#700181
05/17/10 12:23 AM
05/17/10 12:23 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
move the intermeidate shaft.........
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Viol8r]
#700182
05/17/10 12:24 AM
05/17/10 12:24 AM
RapidRobert
w the cap off, hand turn the crank w a 1&1/4" socket/breaker bar until a reluctor blade is lined up w the magnet. Then turn the housing (in the direction you need to) until the magnet is lined up w the next reluctor blade then shift the wires 1 position and fire it up & time it.
[Re: Viol8r]
#700183
05/17/10 12:28 AM
05/17/10 12:28 AM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi rotateing the plug wires 1 space counter clockwise then reset timing by rotateing dist counter clockwise same ammount . or if this is wrong direction go clockwise ! not sure where you are tight ? ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: calrobb2000]
#700184
05/17/10 12:33 AM
05/17/10 12:33 AM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
I am tight on the retarded CCW direction. So its as simple as moving all the wires CW a few spaces and then reset timing? I do not have to do anything with the distributor gear?
[Re: Viol8r]
#700185
05/17/10 12:54 AM
05/17/10 12:54 AM
RapidRobert
turn the dist housing CW to free up the can then shift each wire back CCW 1 position as the rotor is still back in the CCW position and you need it's (orig) wire back on top of it. Ideally you want the wires/terminals in the oe position (#1 slightly to the front pass side) and shifting the inter gear MAY be needed but do the above 1st and start w the reluctor blades lined up so your timing will be very close.
[Re: Viol8r]
#700188
05/18/10 01:30 AM
05/18/10 01:30 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
IF STOCK DIST... the dist/oil shaft must be with the notch parallel ( or really close ) with camshaft when TDC. That will give you vacuum pod pointing out to battery.
That will give you number one pointing out to rear alt bracket
If MP unit ( mallory built )... the notch must be AROUND 70-90º OFF at TDC
That will keep the number one pointing out to rear alt bracket as any stock dist...
Dunno the rest of distributors
