yesterday we did a dynodrive on my new stroker here is the numbers.
block chenoweth block in a bag 440 0,30 over, deck height 0,013 bore 4,3500 stroke 4,150
440 source stroker kit rod lenght 6,7600 flat top pistons
heads edelbrock 84 cc,s gasket felpro 1009
compcam roller rockers
camshaft straighlines performance
lobe lift intake 0,360 exhaust 0,345
rocker ratio 1,5 1,5
valve lift 0,540 0,518
adv dur 294 309
dur@.050 244 256
lobe centerline 108,0 116,0
lobe separation 112
carbs holley six pack
ignition pertronix distrubutor and second strike box
exhaust tti 2" headers
result 540 hp 5500 rpm
torque 587 4400rpm
