Kasey
I honestly thought the exact same thing you wrote. what is the difference if there is bead pit versus 80 grit channels? I dont think any really, both gives tooth, thats about it. My cuda project, my demon, the 65HPP d100 we did, and the charger have all been etch/acid primed from bare metal, nothing lifting off yet. I do it the same way a very light translucent coat.
I guess I just didnt go to college for body work so I couldnt say either way, It just didnt make any sence to me.
Kasey
wow, Yes it's ok to use etch primer first on bare metal, it's recomended.
First off I don't see any difference between blasted and sanded ground metal. it get's treated the same imo.
I have done lots of sand/media blasting and paint work over the years(25).
As soon as I'm done blasting when I have bare white metal before I even touch it, I paint it. The first coat of paint is etching primer. 1 light coat, it's translucent and provides a chemical advantage for top coats. Then within 1 hour or so the second and third coats are epoxy primer. Then at that point within 24 hours if I can, I apply the top coat without any scuffing or sanding. Like say the bottem of your car or inside the car. Wet on wet is best for best results.
Some people will say epoxy directly on bare blasted metal but using etch primer first is better.
Once your metal is blasted bare, you want to coat it fast and definety don't touch it or pre treat with anything, as it as clean as can be after blasting.
I've done entire cars and trucks with the above procedure and still own some of the trucks that I painted 15 years ago. I know what holds up.
Got lot's of pictures of my work.
My 71 has etch primer all over it.
