PPG certified painter here.
it's not recommended to acid etch prime sand blasted metal. because the acid flows into the blasted craters and will bleed into the top coats.
with that said i etch prime sand blasted metal all of the time. just remember not to top coat it with anything for a few days and you will be fine.
perception is 90% of reality
