I may be wrong but I think the scooped alum front end is a super stock designated item only. Not legal for stock. I believe the package was only available with 425 hp.
Look at the classification guide I posted near the top. The aluminum nose and scoop is legal for Stock (and SS). You would have to run the high compression MW and the factor is 7.61 to put a Savoy in AA/SA, or add weight to drop to A/SA. The factor with the LC MW is 8.18 with steel nose and flat hood. Natural A/SA car, move up or down a class.
Floyd Lippencott IV
