What class would a 64 Savoy with 415 hp engine, auto and steel front end fit into? Has anyone tried any of the latest Max Wedge Head offerings from Mopar performance? What other cars would you be competeing with?
That car fits B/SA IF NHRA has not factored the HP on that combination, it might be able to fit C/SA by adding weight, maybe not Check with NHRA tech to find out there rae a lot of different brand cars with different motor combinations that can run B and C/SA. Your best bet for accurate information on this subject is with NHRA and on line at classracer.com
