Basic question is how the upper inner portion of the plastic pillar molding is fastened. There is a hole in the corner piece which lines up with the screw hole in the plastic piece, but no corresponding hole in the pillar itself.
Your not going to believe this. I remember also being confused by that. Then I figured it out and blew through it. That was only a month ago and now I can't remember again.
I think it was a special fastener to back up the screw. Metal and rectangular shaped.
My car has been at the top installer since the 3rd. The installer said, difficult but coming along nicely.
When I get it back, I will look at this for you. But almost positive its a metal clip thats rectangular in shape that goes behind there.
