it's an art isn't it?
Yes it sure is
Have you tried to come off at idle and waffle it?
Not off idle but just off idle raise the r's just high enough to get the lope out and then hammer it
My next question is why is your vacuum so low?
lopey cam • Hydraulic Roller Camshaft — 288°/292° Advertised Duration (230°/234° Duration @ .050") 0.501"/0.513" Lift
Can you adjust on the carb to get more?
i've tried with no luck
I'm using the 166k MP converter. Just going to have to keep playing with it till I find the sweet spot.......or .. and get the check book out
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver
13.83 @ 96.36 1.98 60 ft
2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
