Thanks for the advice guys I'll check the rear brake adjustment out first then go from there. thanks again
You do have discs in the ft right? If so I can`t imagine why the "whole"system can`t keep your car stable/locked on the starting line till you leave. I agree about the vert also.......a looser vert will help in ALL areas as long s it`s a good one and to say a vert has a "2400" stall is a missconception as it`s more related to YOUR power not a GENERAL power.
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
