They are fat, nose-heavy pigs and run like crap. When you are done trying to get traction I will give you a couple bucks for one...
Black AND STRIPE DELETE ...
I'll take it , take a green dart in trade?
Tom , do you have the exhaust manifold$ ?
Though not a good comparision my 69 383 4 speed 3.91 dart went 14.18 at Stanton in 06 weighing 3605lbs w/driver, 56k miles and the timing chain was so loose I could have removed it without removing the gears.
I would imagine that a 440 A body should be running faster than that considering the auto is easier to launch ?
