Tom, i'm not sure of 1/4 mile times for road tests on '69 GTX's back when new. Would have to compare auto and same rear gear. I have most all mags that did '69 M-code 'cuda tests in showroom stock trim. Of coarse the traction was the problem. Generally the 'cuda ran 14 flat, with a best time by one mag at 13.89......You've seen mine run low 14's(IIRC 14.11) without messing with it AT ALL or shifting manually. I bet you could get alot more out of it if you tweeked it your way!!! The notch is 100lbs lighter than the fastback.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
