I'm going with the lunati 60711 cam. Stock oil pump. The 360 has the 308 heads on it, I'm getting those heads checked and if they are cracked what heads would you recommend for replacement? I'm looking towards the aero head brand replacement heads. Also I have an 8.25 ring gear with an 294 ratio. What stall torque converter would be best suited. Any thoughts? Once again thanks for all of your help.
